UDF NEW SOURCE
    • Jancos
      Hi all,
      Can anyone help me with this UDF. After I interpreted my UDF , set UDMs on 4 and put new momentum source I initializate my calculation but when I am checking counturs the values of my UDMs are 0. And when I start calculation my Fluent crashed.
      THIS MY UDF:
    • DrAmine
      We will provide guidance only. Paste the lines here.
    • Jancos
      #include "udf.h"
      #define N 94208
      #define xm -8.86E-9
      #define ro 997.96
      #define beta 21.37E-5
      #define To 298.5
      #define mi 12.566E-7
      #define vf 3.28E-5
      float GradB[N] =
      {...};// my values number of elements 94208
      DEFINE_SOURCE(xmagnetic_source,c,t,dS,eqn)
      real xm_source;
      real Temp;
      Domain *d;
      int i;
      i = 0;
      thread_loop_c(t,d)// loop over all cells in model
      begin_c_loop(c,t)
      Temp = C_T(c,t);
      xm_source=(-((xm*ro*beta*(Temp-To)*GradB*vf)/(2*mi)));
      C_UDMI(c,t,0) = GradB;
      C_UDMI(c,t,1) = xm_source;
      i++;
      end_c_loop(c,t)
      return xm_source;
      DEFINE_SOURCE(ymagnetic_source,c,t,dS,eqn)
      real ym_source;
      real Temp;
      Domain *d;
      int i;
      i = 0;
      begin_c_loop(c,t)
      Temp = C_T(c,t);
      ym_source=(-((xm*ro*beta*(Temp-To)*GradB*vf)/(2*mi)));
      C_UDMI(c,t,2) = ym_source;
      i++;
      end_c_loop(c,t)
      return ym_source;
      DEFINE_SOURCE(zmagnetic_source,c,t,dS,eqn)
      real zm_source;
      real Temp;
      Domain *d;
      int i;
      i = 0;
      begin_c_loop(c,t)
      Temp = C_T(c,t);
      zm_source=(-((xm*ro*beta*(Temp-To)*GradB*vf)/(2*mi)));
      C_UDMI(c,t,3) = zm_source;
      i++;
      end_c_loop(c,t)
      return zm_source;
    • DrAmine
      Actually there is no need to do a loop inside of a define source udf. Check the manual for more details and attend a training if possible. Gradb is declares but not defined. You require a loop if the counter i if you need to use values from the array.
    • Jancos
      In my array i have values which represent gradient of magnetic field in every cell center, so I need to have it . And my loop in define source calculate in every cell value of magnetic buoyacy force. Do you have any idea how write this UDF?
    • DrAmine
      Check the manual and standard C manuals.
Viewing 5 reply threads
