March 9, 2021 at 8:43 am
ashch
SubscriberHi,
I am trying to execute a UDF (Define_Spcific_Heat) that runs nicely on my own machine. However, I am facing issues when trying to execute the same via a batch job on the HPC. The sequence of my workflow is as follows, please let me know if it needs any correction
- I have complied the UDF on my machine (Cp inputted as a user-defined function) and then exporting the cas file to be run on the HPC.
- The directory of the HPC contains both the cas file and the libudf folder
- The journal file has the following commands
- /define/user-defined/compiled-functions compile libudf yes 'Specific_Heat.c' ""
- /define/user-defined/compiled-funcitons load libudf
- Finally the error I get is as follows:
for d in lnamd64/[23]*; do ( cd $d; if [ -f udf_names.c ]; then mv -f udf_names.c udf_names.cRenamed; fi; rm -rf *.{c,h,cpp,hpp}; if [ -f udf_names.cRenamed ]; then mv -f udf_names.cRenamed udf_names.c; fi; for f in ../../src/*.{c,h,cpp,hpp} ../../src/makefile ../../src/user.udf; do if [ -f $f -a ! -f `basename $f` ]; then echo "# linking to" $f "in" $d; ln -s $f .; fi; done; echo ""; echo "# building library in" $d; if [ "" = "1" ]; then echo "# using gcc64"; make ARCHC=gcc64 -k>makelog 2>&1; else if [ "" = "1" ]; then echo "# using gcc"; make ARCHC=gcc -k>makelog 2>&1; else make -k>makelog 2>&1; fi; fi; cat makelog; ) done # linking to ../../src/Specific_Heat.c in lnamd64/3ddp_host # building library in lnamd64/3ddp_host make[1]: Entering directory `/zhome/d7/e/113826/Ashish/Corner_Air_Gap_200_290/libudf/lnamd64/3ddp_host' make[1]: *** No rule to make target `compiled-funcitons', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `read-case', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `FLTG.2-Setup-Output.cas.gz', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `libudf', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `load', needed by `'Specific_Heat.c''. make[1]: Target `default' not remade because of errors. make[1]: Leaving directory `/zhome/d7/e/113826/Ashish/Corner_Air_Gap_200_290/libudf/lnamd64/3ddp_host' # linking to ../../src/Specific_Heat.c in lnamd64/3ddp_node # building library in lnamd64/3ddp_node make[1]: Entering directory `/zhome/d7/e/113826/Ashish/Corner_Air_Gap_200_290/libudf/lnamd64/3ddp_node' make[1]: *** No rule to make target `compiled-funcitons', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `read-case', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `FLTG.2-Setup-Output.cas.gz', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `libudf', needed by `'Specific_Heat.c''. make[1]: *** No rule to make target `load', needed by `'Specific_Heat.c''. make[1]: Target `default' not remade because of errors. make[1]: Leaving directory `/zhome/d7/e/113826/Ashish/Corner_Air_Gap_200_290/libudf/lnamd64/3ddp_node'
March 9, 2021 at 6:25 pmSurya Deb
Ansys EmployeeHello, nPlease check the command in point #5. You have a typo there in the word functions /define/user-defined/compiled-funcitonsload libudf . You have used a wrong spelling. Please correct this and recheck.nHope this helps.nRegards,nSDMarch 10, 2021 at 7:45 amashch
SubscribernThanks fo your comments,nUnfortunately, I'm having the same problem and errors as before.Thanks,nAshishnnMarch 11, 2021 at 4:47 pmSurya Deb
Ansys EmployeeHello, nDid you try setting environment variables properly? You might want to check the link below.nexport FLUENT_ARCH = lnamd64 can be also tested before you launch Fluent.nRegards,nSDnViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2508
2064
1277
1088
456
