July 25, 2019 at 10:50 am
Benito
SubscriberHi everyone, I need some help with writing a UDF. I need write a code for simulating a car airbox for my final tesis, where you have an velocity inlet costant of 53m / s and 4 output tubes that have a mass flow outlet of 0.0045kg / s each. This outflows should have a pulsed output flow. Furthermore the exit from the pipes should take place in this order like a normal engine ignition configuration.(pipe 1;pip 3;pipe 4;pip 2).
Can you help me with this issue.
Thank you
Benito Asturio
2656
2120
1347
1118
461
