September 2, 2019 at 11:11 am
louai
SubscriberDear
i have created a user defined variable for post processing proposes
however i am writing UDF which needs this user defined variable as an input
i was wondering how can i achieve this
best regards
September 2, 2019 at 12:11 pm
Ansys EmployeeWhat variable have you created? You may be better off calculating the value in the UDF, and if it's a field value post processing that rather than what you've done. More information will help.
September 2, 2019 at 1:51 pm
louai
Subscriberthanks for the prompt reply @rwoolhou
lets make it a general question , if a user defined variable has been created for any reason , is there a way to refer to it inside the UDF as it is
i have tried using RP_Get_Real("variable-name")
where for the variable name i put the name given for the user defined variable but an error returned says an identified variable
regards
September 2, 2019 at 2:28 pm
DrAmine
Ansys EmployeeRefer to Fluent Customization manual under Accessing a Scheme Variable in a UDF
2524
2066
1279
1096
457
