November 24, 2020 at 12:23 am
md_lidia
SubscriberNovember 24, 2020 at 11:19 amRob
Forum ModeratorI suspect it's the first part of the IF statement. Simplify the set to get it working (eg 1-2 pulses) then extend to 40+s. nNovember 24, 2020 at 1:10 pmDrAmine
Ansys Employeewhy not using just a transient table without any UDF or using Fluent Expression: why always getting the most complicated approach.nRegarding UDF: where are you hooking it?nViewing 2 reply threads- The topic ‘UDF VELOCITY INLET PROFILE WITH MULTIPHASE MIXTURE (ANSYS FLUENT)’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
