udf_names.c Error
    • Jeroen
      Hello
      I am trying to compile my UDF of type DEFINE_DPM_HEAT_MASS() and it seems to be free of errors and warnings. However, during compiling and building the library I get an error whilst udf_names.c is generated by ANSYS (see below). I opened this file and it specifically states to not make any changes to it.
      How come I get this error and how can I solve it?
      Copied C:Userss151272DocumentsMasterAfstudeer_opdrachtANSYSReact_Hematite.c to libudfsrc
      udf_names.c and user_nt.udf files in 3d are upto date.
      (system "copy "C:PROGRA~1ANSYSI~1v195fluent"fluent19.5.0srcudfmakefile_nt.udf "libudfwin643dmakefile" ")
      1 file(s) copied.
      (chdir "libudf")(chdir "win643d")udf_names.c
      udf_names.c(7): error C2059: syntax error: '}'
      udf_names.c(8): warning C4034: sizeof returns 0
      Done.
      Kind regards,
      Jeroen
    • DrAmine
      Check if white spaces are there and udf name. All arguments to be put on the same line
    • Jeroen
      My function declaration is as follows:
      DEFINE_DPM_HEAT_MASS(hematite,p,Cp,hgas,hvap,cvap_surf,Z,dydt,dzdt)
      There are no whitespaces and all arguments are on the same line.
    • DrAmine
      And the right bracket,,? What happens if you just copy the example from Manual,?
    • Jeroen
      I have tried to run a UDF code that was sent to me in a previous question I asked on this forum. However this gives the exact same error.
      There is also no whitespace before or after the closing bracket in my code.
    • DrAmine
      Try the one from manual and let me know before that try a simple Hello World On demand UDF.
    • Jeroen
      For both the code provided in the manual and a simple Hello World On Demand UDF i get the same error.
      The code I use for the Hello World UDF is as follows:
      #include "udf.h"
      DEFINE_ON_DEMAND(on_demand_calc)
      Domain *d;
      Thread *t;
      d = Get_Domain(1);
      message("Hello Worldn");
    • DrAmine
      Okay what you are sharing is definelty wrong. Check this
      How to access the ANSYS Online Help
    • Jeroen
      Your code gives me the exact same error:
      ** WARNING: Automatically switched to run in parallel -t1 mode. **
      ** Detected non-parallelized UDF usage, enabling parallel usage. **
      ** If you encounter any issues, please re-run with -t0 flag. **
      ****************************************************************************udf_names.c and user_nt.udf files in 3d_node are upto date.
      (system "copy "C:PROGRA~1ANSYSI~1v195fluent"fluent19.5.0srcudfmakefile_nt.udf "libudfwin643d_nodemakefile" ")
      1 file(s) copied.
      (chdir "libudf")(chdir "win643d_node")# Generating ud_io1.h
      Hello.c
      # Generating udf_names.c because of makefile Hellbj
      udf_names.c
      Done.
    • DrAmine
      The error is related to the udf_names which does tell me that there was no DEFINE macro defined in the UDF. If you open udf_names.c you will on line 6 to 7 that the array is empty. Something is still wrong with the UDF you are using (even the one which is posted perhaps you have white spaces,...) I do not know.
Viewing 9 reply threads
