UHPFRC MODELISATION – CAST IRON
    • WillGOMEZ
      Hi everyone !
      I'm trying to model the UHPFRC comportement in Ansys, but I'm new in the plasticity subject.
      For the compression zone I can add the isotropic elasticity to the material data, but for the tension part, I would like to know if I can give the material a multilinear isotropic plasticity just for its tensile zone or if it's better to use the Cast Iron model where I can separate each curve (tension and compression) and then change the Rankine yield criterion for a Von Mises yield criterion.
      Thank you for your comments.
Viewing 0 reply threads
