Ultrasonic Transducer
    • dardhruv
      Hello All,
      I am doing an acoustic simulation of Capacitive Micromachined Ultrasonic Transducer simulation.
      Basic Structure of CMUT:
      https://www.engineeringsolutions.philips.com/looking-expertise/mems-micro-devices/mems-micro-devices-applications/capacitive-micromachined-ultrasonic-transducers-cmut/
    • Erik Kostson
      Hello
      You will only get pressure (bulk/acoustic) waves in the fluid (Lamb, are guided waves in plates, or Rayleigh surface waves on thick structure, or in plates if the frequency-plate thickness product is high enough).
      So once the membrane oscillates it will generate acoustic waves in the fluid (excitation mode), or if the acoustic waves excite the memearne one will register a voltage (receiver mode)
      The question also is not clear. You already say that you use static and harmonic, so you have the modules you want to use.
      Thank you
      Erik
    • dardhruv
      Hello Sir Yes, I have substrate also in CMUT so It might affect. right? I would like to check the effect on the membrane or on the substrate.
      Two membranes are there, one is fixed which is substate and another one is movable.
      My task is to check whether Lamb, Scholte, Rayleigh or stonely wave present or not.
      Is there any tutorial available regarding this?
      Thanks and Regarding Dhruvin
    • Erik Kostson
      Hi
      I do not think so - what is the operating frequency/driving freq., and thickness of the substrate (also material)?
      Finally, why do expect guided/surface waves on the substrate (have you measured them or)?
      ALso is this part of a research project, and are you a research student (you only provide a gmail, so I can not see if you are a research student)?
      In any case we do not have any material on this.
      Thank you
      Erik
    • dardhruv
      Hello Sir My CMUT device has a 1.8 MHz driving frequency and substrate thickness is 100 um. top membrane thickness is 5.5um
      yes, I am research student in Fraunhofer ENAS.
      Thank you
      Dhruvin
    • Erik Kostson
      Hi
      Ok, it is hard to calc this one, but for that thickness I do not expect any surface waves, only guided waves (Antisymmetric branch mostly say A0 mode).
      I would add your uni. email in your profile not the gmail one .
      Again we do not have any examples on this.
      Erik
    • dardhruv
      Hello Sir
      I have added my institute email id.
      Does it mean I can't check any of this wave using ANSYS?
      Thank you
      Regards Dhruvin
    • Erik Kostson
      Hi
      Did not say that, I said that I have not seen any examples of this - you might still be able to do what you want, but you would need to find out by trying yourself (so static dc bias followed by harmonic).
      Also do you use solid226 for the internal airgap and to get the capacitive force on the membrane?
      I would also say that the Lamb waves are mostly excited by the two support legs on either side of the membrane thus transferring the vibrations into the substrate.
      All the best of luck -
      let us know how it goes, and how you progress.
    • dardhruv
      Hello Sir I have used the Trans126 element to do mesh for the vacuum gap between the Membrane and the Substrate.
      Here I have attached a prestressed harmonic file.
      I don't know, Is it ok if I also define substrate beneath trans126? to check the effect of the lamb wave I have to define substrate also. right?
      Thanks and Regards Dhruvin
    • Erik Kostson
      Unfortunately we can not download this - put some inline images of the model. Also include some results
      To answer your question, yes, you would need the substrate to check for Lamb waves and standing waves there - show a stress result (inline image), for the simulation at the driving freq. (1.8 MHz).
      thank you
      Erik
    • dardhruv
      Hello Sir static analysis:
      Harmonic Analysis:
      pressure on top of membrane:
      Please check this?
      If I add substrate then it will not affect trans126?
      I always thought if I have defined trans126 then why should I add substrate. But now I think I was wrong.
      It should be there to check wave propagation on a substrate. right?
      is there any example where trans126 and also bottom substrate present
      Thanks
      Dhruvin
    • Erik Kostson
      THat looks sensible perhaps - you know if the resonance is ~ 2 MHz :) - suppose you measured it?
    • dardhruv
      Hello Sir Yes, It's nearly 2 MHz.
    • Erik Kostson
      Ok - thanks.
      Yes, if you need to check for vibrations/waves on the substrate, then it needs to be modeled.
      Try that and I think it might be fine. Unfortunately we do not have any examples on this type of application since it is very niche.
      All the best
      Erik
    • dardhruv
      Hello Sir
      Could you please let me know how to check if waves are there on the substrate?
Viewing 14 reply threads
