November 30, 2020 at 8:23 am
saturren
SubscriberDear All,nnCurrently, I am working on user-defined material subroutines for accurately simulating the response of concrete structures against impact or blast in LS DYNA. To run the code, I need the so-called usermat package. However, I cannot find it by myself. I am writing this email to enquiry that whether anyone can provide me with a copy of the usermat package, which includes several files such as library files(*.a), object files (*.o), include files (*.inc), Fortran files (*.f) and a Makefile.nnThank you in advance for your kind help and sorry again for any inconvenience caused.nnThanks and best regards,nFenglingn -
November 30, 2020 at 10:37 am
saturren
SubscriberI forgot to mention the following information. Just let me know if I need to provide other information. You can contact me via fenglingzhang@u.nus.edu
I am from the Department of Civil & Environmental Engineering, National University of Singapore. The network license manager is CSI_Server_2016.
LS DYNA will be run in Windows 10.
I use LS DYNA version is ls_dyna_smp_d_R11_1_0_winx64_ifort160.
January 13, 2021 at 2:11 pm
July 13, 2021 at 6:21 pm
sjulien
Subscriber.I had the same question. Thank you for the link. Very helpful. Credentials can be provided by your ANSYS/LS-DYNA rep, upon request.
February 17, 2023 at 10:30 pm
Tuan Nguyen
SubscriberI also face the same problem. I ask people in forum they said that we need to have LS_DYNA license and download it in ftp.lstc.com. Please share with me how to compile when you figure out the way.
- The topic ‘UMAT in LS DYNA’ is closed to new replies.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1680
1470
