3D Design
3D Design
‘unable to attach Geometry’ and ‘The geometry editor colsed abnormally’
    • ak22
      In ansys 19.2 after drawing geometry (surface), when i close ansys dosen't tick mark green against geometry. If I import it, it does tick mark green but after opening model there is error unable to attach geometry.
      I tried solutions of similar threads but none of it worked. Please help
      System.Exception: Unable to attach to geometry file C:UsersangarDocumentsansys2dbar.scdoc. Unable to attach geometry.
         at Ansys.Simulation.Core.Commands.RefreshModel.ExecuteCommand(IFullContext context)
         at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
         at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
      --- Ansys.Core.Commands.CommandFailedException: Unable to attach to geometry file C:UsersangarDocumentsansys2dbar.scdoc. Unable to attach geometry.
      CommandName: Mechanical.RefreshModel(Container="Model", RemainingContainers=[])
         at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
         at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
         at Ansys.ProjectSchematic.Commands.RefreshCommand.RefreshComponents(IFullContext context, IEnumerable`1 componentsToRefresh, Boolean refreshUnfulfilled)
      CommandName: RefreshComponent(Component="/Schematic/Component:Model")
         at Ansys.ProjectSchematic.Commands.RefreshComponentCommand.InvokeAndWait(IProtectedContext context, DataReference Component)
         at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation(GuiOperationContext context, IGuiOperation guiOperation, DataContainerReference dcr)
         at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
         at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
    • Keyur Kanade
      can you please insert images. it is not clear to me if you are closing spaceclaim or ansys.
    • ak22
      after closing spaceclaim only
    • Fernando Torres
      Hi , change analysis from '3d' to '2d' and check if it makes any difference. Thanks.
    • ak22
      its solved by changing extension from sdoc to igs
      thanks
    • Keyur Kanade
      good.
      please mark this as 'is solution' to help others on forum.
Viewing 5 reply threads
