unable to converge creep simulation in workbench
    • gopikrishna
      i need to simulate a round bar for creep in which one end is fixed and other is applied by a tensile load. the problem is my simulation is not converging. i have tried changing substeps, applied fine mesh, rechecked creep constants and units still problem exists. please help me to sort out this problem.
    • gopikrishna
      please help guys
    • peteroznewman
      ANSYS staff are not permitted to open attachments. Please insert the images into your post. You can leave them attached also. as that is easier for me to open.
    • gopikrishna
    • gopikrishna
      sir i have inserted the images.
    • peteroznewman
      Does it fail to converge at the beginning or does it start and fail to converge at the end?
      What happens if you set the Initial Substeps to 1000?
    • gopikrishna
    • gopikrishna
      sir , is negative creep constant can be a problem for convergence??
    • peteroznewman
      I went to the ANSYS Help system, and found the equation for Norton so that I understood the creep model in another discussion.
      ANSYS Help > Home > Mechancial APDL > Material Reference > Nonlinear Material Properties > Rate Dependent Plasticity > Creep
      The Combined Time Hardening entry says only C1 > 0 and C5 > 0.
      Where did you obtain the creep constants?  What units of stress are required to use those constants?
      It seems your solution begins, so you have some results.
      Please reply with a snapshot of the graph of maximum displacement vs. time.
    • gopikrishna
      Sir, i took the values for strain and time from strain vs time plot and transferred those values to APDL. Then using curve fitting in APDL i solved and got the values. My stress value is 18 Mpa and temperature is 900 degree celsius  for a time of 14000 hours
    • gopikrishna
    • gopikrishna
    • peteroznewman
      Try setting Minimum Substeps to 1000 since the solution converges a few initial steps.
    • gopikrishna
      sir, still not converging. Any other solution??.
    • peteroznewman
      What is the error description on the Solution Output?
    • lroblek
      How did you get the Combined time hardening coefficients? Via APDL Material models? You have fixed C4=0, so I assume you don't have temperature dependant model.
      Try to fix C2=1, C4=0, C6=1 and C7=0 (fixed stress and no temperature dependancy) in the Curve fitting tool and try to run the simualtion again. The creep behaviur curve should be nearly the same (you can compare to the current one that you have). Put fixed values in the Coeff Value, Fix them and click Solve to get new values for the creep simulation.
    • gopikrishna
      sir , i changed the constants still its showing error
    • gopikrishna
      sir same error its showing
    • gopikrishna
    • gopikrishna
      force convergence plot
    • lroblek
      Can you try a constant Creep strain model, such as Norton and put Auto Time Stepping to Program controlled.
    • gopikrishna
      sir actually the data is got is only strain vs time data...can you please tell me how to derive creep constants for norton equation
      if i try to get the data from APDL i need creep strain rate vs time data that i dont have...can you pls share me the way i can derive these constants for norton.
    • gopikrishna
      Sir, how i can send you my model to check the actual mistake??
    • peteroznewman
      When a nonlinear static structural model fails to converge, that can be the expected outcome of the simulation. For example, if the material is Bilinear Isotopic Hardening, with 0 Tangent Modulus, it is perfectly plastic above the yield strength. If a force is the applied load, once the force is high enough to turn the entire section plastic, there is no static equilibrium above the force increment that just converged, every force above that will fail to converge. There is no mistake in the model, that is the natural end of the simulation for a problem where the ultimate load was unknown.
      Your model converges for many time steps, then stops converging. Look at the results. Plot the force vs time curve. What does it look like?
    • gopikrishna
      Sir, what is the significance of creep limit ratio. what if i put creep limit ratio as zero, because if im assigning creep limit ratio as zero solution is converging!
      sir also if we get the creep constants for a material, then with that creep constants can we simulate the model for any stress, temperature, and time values?? i mean the same creep constants can be applied for a specific material for any of its creep simulation??
    • peteroznewman
      Plot the force vs time curve. I want to see that before I say anything more.
    • gopikrishna
      thank you Sir, problem is solved. Actually i had some problem with my constants, i was able to find the constants from another experimental data..
    • gopikrishna
      Sir if i want to do a coupled simulation of thermal cycling with creep, how can i do it. Since creep constants depends on temperature, so during thermal cycling temperature is continuosly changing..can you explain please!
    • peteroznewman
      Insert a Thermal Condition load and set the temperature for each time step. I have used 1 second time steps but you can use 100 or 1000 seconds as needed.
    • gopikrishna
      thank you sir, but what about creep constants?? it depends on temperature, therefore it can vary with temperature. So if im doing thermal cycling, temperature is continously varying. In my case temperature is varying between 900 to 400. So should i choose creep constants for 900 or 400 or in between some value and carry out simulation??
    • gopikrishna
      Sir, whether we will apply damage evolution law for creep simulation??. because in the real case necking is happening at the heat affected area at the center of the bar. In simulation the way it is failing by creep is complately different.
    • krishna1983
       @Gopikrishna, I am fresher to Ansys Creep analysis. I need some help from you.
      I have a reactor, material is 1.25cr-0.5mo. The design temperature is in creep range. So i need to perform creep analysis to obtain creep strain. I have rupture data from ASTM DS-50.
      My material model is Norton (for secondary creep). Then how i derive creep constants from APDL. Kindly explain.
      Besides, could you please share your model, so that it will be helpful for my project.
      Your help is appreciated.
    • Patti
      Hello Gopikrishna,I think I actually have the same problem you have once regarding the constant of norton law. nYou wrote that you find another way to identificate the constants. Can you please tell me how you did it?.I got creep test data deformation vs. time or creep strain vs. time. nI tried to fit the creep curve in APDL (Norton) but it doesnt worked. Error during solution. Only Modified Time Hardening and Generalizied Time Hardening worked. But with the constant of these creep law - the simulation doesnt converge.nnMaybe you can help?nThanks in advance.n
Viewing 32 reply threads
