July 17, 2017 at 2:07 pm
Zohreh
SubscriberHello every body!
I'm working on Box girder model. I wanna apply force until it will be broken. The box Girder has 2 arms. forces are applied on arms. But the solution can't converge. I checked everything like materials, mesh size , changed sub steps, load steps and NSF(Normal stiffness factor) and etc but they didn't work. how can i solve it? could you help me? -
July 18, 2017 at 9:48 pm
pgl
Ansys EmployeeSounds like a large deflection buckling simulation? If you are using Workbench then take a look at the product documentation Static Structural Analysis section starting on page 316. In that section review the following:
- Establish Analysis Settings (page 318) - See the note about Large Deflection
Also see these important sections
- Large Deflection (Page 843)
- Nonlinear Controls (page 860)
If you are old school and using ANSYS M-APDL then lookup the command NLGEOM,ON
Here's some scholarly articles on box girder simulations using ANSYS found on the web:
July 19, 2017 at 2:04 pm
Zohreh
SubscriberHello Dear pgl!
Thank you for helping. Yes, It's a large deflection buckling simulation. I'm using workbench. I don't know where is product documentation. How can I find it?
Thank u...
July 20, 2017 at 12:02 am
pgl
Ansys EmployeeOn Windows 10, go to your Windows/Start menu, select "All apps" then "ANSYS 18.0" scroll down the list of ANSYS applications and select "ANSYS Help 18.0"
August 9, 2017 at 4:38 am
ding
SubscriberYou can also change the criteria of convergence. If your model is concrete, please try to select displacement criteria of convergence. You can achieve it by using "CNVTOL,u,1,0.001,2"
3419
2475
1310
1022
