September 19, 2018 at 6:26 pm
jrozsa
SubscriberI am trying to run hundreds of simulations simultaneously on a supercomputer. Most of the simulations run fine but some are not able to be analyzed. The error message that is output is:
"unable to create child process: G3dMesher, error code = 2
Does anyone know why this could be?
September 20, 2018 at 1:06 am
Karthik R
AdministratorHello,
Which tool are you using? How are you submitting your jobs? Workbench? RSM?
Best,
Karthik
September 20, 2018 at 9:25 pm
jrozsa
SubscriberI'm using the electrostatic analyzer. The scheduler we're using is slurm.
- Maxwell, HFSS or Q3D?
- Error
2630
2110
1335
1110
461
