Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Unable to create Mid- Surface for the Hemmed Sheet metal
    • happykiran
      Hi I was trying to extract Mid-Surface for my sheet metal design which is modeled with Hem when i extracted it was coming as two seperate surfaces. help me to extract Mid surface
    • peteroznewman
      Split (or slice) the body that has the hem on it at the bottom of the hem edge. Now you can assign a double thickness to the body that has the hem, while letting the rest of the body have a single thickness.  Suppress or delete the separate surface.
    • happykiran
      Thanks for the solution and I tried and not able to get it can u please help me step by step guidelines.
    • peteroznewman
      • Please attach the geometry file so I can show you (put in a zip file if it is not an allowed extension).
      • What CAD system was it designed in?
      • Which CAD system are you trying to create the Midsurfaces?
      • What version of ANSYS are you using?
Viewing 3 reply threads
