January 24, 2022 at 2:37 am
rasyiqah
SubscriberHi, I am trying to deactivate my license on my computer so as to be able to use Lumerical FDTD on another computer. However when I try to deactivate the license on the Lumerical launcher, an error message saying "Deactivation failed with error code 6". Please advise as to what i should do next. thank you!
January 24, 2022 at 11:13 pmLito Yap
Ansys EmployeeI will reply to you via email to resolve this issue.
March 7, 2022 at 12:50 pmssj_987
SubscriberHi I am also facing similar issue. How can I resolve this problem?
Thanks in advance
March 7, 2022 at 5:18 pmLito Yap
Ansys EmployeeIf you have a trial license, you cannot deactivate or move your trial license.
May 17, 2022 at 9:41 amcttcupc
SubscriberHello,
I have the same problem , can anyone assist me please ? I have a license but I do not have access to my email that has the license anymore. I have my activation code however.
May 17, 2022 at 6:06 pmLito Yap
Ansys EmployeeAs mentioned in this thread, trial licenses cannot be moved or deactivated. Please contact your Ansys account manager or the representative for your region for licensing options prior to your purchase.
Viewing 5 reply threads- You must be logged in to reply to this topic.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8786
4658
3151
1680
1470
