February 12, 2022 at 7:05 pm
gogogog
SubscriberHi, I am trying to deactivate my license on my computer so as to be able to use Lumerical FDTD and Charge on another computer. However when I try to deactivate the license on the Lumerical launcher, an error message saying "Deactivation failed with error code 6". Please advise as to what i should do next. thank you!
February 14, 2022 at 6:49 pmLito Yap
Ansys EmployeeEvaluation/Trial licenses cannot be moved to a different computer . Try to request for an evaluation/trial license from your Ansys Account Manager or an Ansys Lumerical representative in your region.
February 15, 2022 at 9:10 amgogogog
Subscriberwhat is the difference between trial version and evaluation version please?
February 15, 2022 at 5:59 pmLito Yap
Ansys EmployeeThey are both the same. Evaluation license are also called trial license.
- Error on Lumerical device
3780
2587
1835
1244
600
