Unable to display particle tracks
    • Jifweif151
      I am trying to simulate cases of particles released by coughing. My geometry is simply a small cylinder like an oval cavity which is inside an enclosure. I followed the DPM setup tutorial but I still couldn't display the particle tracks after calculation. Here are more info:
    • DrAmine
      You have 70 particles in the domain. There are there. If you run the case what does Fluent tell you?n
    • Jifweif151
      here is one of the time steps shown in the console when I ran the calculation: nn
    • DrAmine
      You should be able to show the tracks. Create a new object and screeshot the panel. You can even write current positions into a file.n
    • DrAmine
    • Jifweif151
      Array n
      Add Tags
