March 22, 2022 at 10:18 am
f20180958
SubscriberI have a pipe. In the interior region named 'water domain', water is flowing and the annular region named 'pipe' is made up of aluminum. For water, there is an inlet and an outlet from the other end. The outermost surface of 'pipe' is named - 'finally_outerWall'.
March 22, 2022 at 11:08 amRob
Ansys EmployeeIf that's the wall next to the solid at the very outside of the domain there's nothing to add momentum too. What are you trying to mimic?
March 22, 2022 at 11:19 amf20180958
SubscriberI wanted to give a sinusoidal vibration f(time) = sin(200*t/1[s]) to the external wall at the outermost surface. Trying to compare the flow variables for the vibrating wall and the static wall. Is there any other way?
March 22, 2022 at 11:44 amRob
Ansys EmployeeThe vibration won't transmit though the solid zone, you could lose the solid and put the boundary on the wet wall. As it's an adiabatic wall where is the heat going?
March 22, 2022 at 2:35 pmf20180958
SubscriberVery Initially I was working on an adiabatic case, but now it's not the same and I didn't bother renaming that. And thanks a ton for your help, I'll go check it out. Thank you.
Viewing 4 reply threads- You must be logged in to reply to this topic.
2688
2134
1349
1136
462
