Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Unable to import geometry into fluent mesher
    • Nathan Strange
      I have been unable to import any geometry when trying to use Ansys Mesher. I import the CAD file and get the error message below, and no geometry appears on screen. I've tried using many different file types, and ran the CAD configuration manager but none of this has helped. I've run out of things to try from the internet so any other things to try would be much appreciated!
      Error: Error in CAD Import
      Error Object: #f
      Error: Error occurred during import.
      Error Object: #f
      Error: Importing the selected file could not be completed. Check to make sure that the selected file format is supported. In addition, check to make sure the CAD Readers are properly configured for the format using the CAD Configuration Manager utility.
      Error Object: #f
    • Essence
      Is your geometry clean? Make sure it does not have any clearances or gaps. If there are faults in the geometry, I would suggest you to use Fault-tolerant meshing.
    • Nathan Strange
      I've tried a couple of different ones, even a basic square, and still get the issue, so feel like it's not the geometry itself causing the problem. I can't think of anything else to change in the program though.
      For more context I'm using a Pro license and am creating the geometry in ironCAD. I can't use the Ansys CAD tools because of licensing issues.
    • Essence
      For Fluent meshing, supported file types are SpaceClaim (.scdoc), Discovery (.dsco), and Workbench (.agdb) files and also .pmdb files for Ansys CAD. It also supports other CAD software. Could you please mention which other CAD software you used?
Viewing 3 reply threads
