March 15, 2023 at 10:30 am
March 15, 2023 at 2:58 pm
Dan Dvorscak
Ansys EmployeeIf you are tying to go from Altium to the Electronics Desktop, I would recommend using the direct EDB exporter instead of ODB++. Here is a link to that process from the Altium side:
Interfacing to the ANSYS Simulation Tools from Altium Designer | Altium Designer 23 User Manual | Documentation
- Maxwell, HFSS or Q3D?
- Error
3694
2564
1765
1234
590
