January 5, 2018 at 9:11 am
Vishal Ganore
Ansys EmployeeHi Friends,
Currently Workbench is not taking Parasolid file through import option in ANSYS Student V 18.2. Highlighted error in ANSYS Meshing is shown below:
Workaround: You need to import the file in Design Modeler (DM) first and then proceed for meshing.
Hopefully we will fix this bug in our upcoming version soon.
Thanks & Regards,
Vishal
January 5, 2018 at 11:00 am
SubscriberHi Vishal,
The same behavior was in Student 17.2 also and the same workaround was used.
I have a commercial license at work which includes Parasolid Import, so I can import in Workbench. The simple fix is to add the Parasolid import license to the Student license.
January 5, 2018 at 11:39 am
Vishal Ganore
Ansys EmployeeThanks for the clarification Peter. Let me work with licensing team.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5162
3251
2443
