3D Design
3D Design
unable to import solidworks 18 files
    • sanju111
      when i try to import a solidworks 18 file into ansys 19 ,I am getting an error saying "file version not supported "
    • Sandeep Medikonda
      Hi Sanju,
        Please see this document on CAD Platform support.
        The Reader only supports Solidworks 2017 but the Plugin would support 2017 and 2018. For differences between the 2, please see this section of the help documentation.
      Sandeep
    • sanju111
       thank you Mr.sandeep , is there any other way so that I can  import files in reader cad mode
    • peteroznewman
      Hi Sanju,
      You can Save As... Parasolid in SolidWorks, then Import the Parasolid file into DesignModeler using File > Import External CAD file, or you can open the Parasolid file with SpaceClaim.
    • Keyur Kanade
      You can use SpaceClaim to import solidworks file.
      You can also use setting -
      File - spaceclaim options - File options - Workbench - Always use spaceclaim reader
      Keyur
Viewing 4 reply threads
