Unable to import Static Structural solution into ACP Post
    • Carlos Enricque
      When I complete the analyze on the static structural I don't have the option to export the solution to the results of the acp post, and them i can't analyze the failure criterion.
      Somebody can help me?
    • maurya
      hello Carlos
                               put the solution from static  structural into ACP post  result then only it will work. other connection are ok.
       there are two type of symbol generated when you link the one module to another
      1) share the result   : circle
      2) share the data    : square
