Ansys Gateway powered by AWS
Unable to install Service.
    • Sebastien Boivin
      Hi everyone,
      I tried to install the AD connector service on a win 2022 server, and ran into that error..   The firewall is turned off for troubleshooting.
      When I execute the command here.
       .\install.ps1 -username "AnsysADaccount" -password "E.................................x" -thumbprint "b..............................cfc"
      it returns:  Ansys.Gateway.AdConnector.exe : Can't connect to ldap server
      What is strange here, is if I run .\install.ps1 and answer each prompt with the same value above, I can launch it but get that error here.
       info: Program[0]
            Start new service.
      SERVICE_NAME: Ansys.Gateway.AdConnector
              TYPE               : 10  WIN32_OWN_PROCESS
              STATE              : 2  START_PENDING
                                      (NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
              WIN32_EXIT_CODE    : 0  (0x0)
              SERVICE_EXIT_CODE  : 0  (0x0)
              CHECKPOINT         : 0x0
              WAIT_HINT          : 0x7d0
              PID                : 6308
              FLAGS              :
      Ansys.Gateway.AdConnector.exe : No connection could be made because the target machine actively refused it. (localhost:16402)
      At C:\agw\install.ps1:44 char:5
      +     & $exe install
          + CategoryInfo          : NotSpecified: (No connection c...ocalhost:16402):String) [], RemoteException
          + FullyQualifiedErrorId : NativeCommandError
      Has anyone had the same problem?
    • Masataka Nakamura
      Hello Sebastien, The username should be in the format “username@domainname”.  If you have not specified it in that format, could you please try again.
      e.g.
      . \install.ps1 -username “domainjoin@company.com” -password “agw……” -thumbprint “b……………………………………..0″
