Ansys Free Student Software
unable to load project in ANSYS
    • Fremol
      I can't open projects done by old version using current version of ANSYS 2020 R1.
      Here is the screen shoot:
      Any ideas/help appreciated!
    • tsiriaks
      What if you move the project to be under C:\Temp and try again ?nMake sure you have its corresponding project folder under the same directoryn
    • Fremol
      Thanks Tsiriaks for your comment,nI tried but it doesn't solve the problem.nn
    • tsiriaks
      If you use this exact .wbpj file and project folder with old version now, does it work ?nDo you have other projects that you can try opening with 2020 R1 ? Do they have the same issue ?n
    • Fremol
      @ tsiriaks,nUnder C:\Temp: the project works with ANSYS 19.2 but not with 2020 R1.nOther projects previously done by ANSYS 19.2 can be opened by 2020 R1.nThank you,n
    • tsiriaks
      I see. So there is something specific to this project that can't be migrated to the new version.nI would recommend to create another post under this sectionnArrayand describe what you have in this Workbench project and if applicable, show the screenshot of your Workbench schematic for this project (of course when open with 19.2)n
    • Fremol
      Thanks tsiriaks! nI will create new post.n
    • tsiriaks
      sounds good.nThank you.n
Viewing 7 reply threads
