September 24, 2018 at 11:33 pm
knnn
SubscriberHi everyone,
I am wondering what this message means in ansys electromagnetics suite. "Unable to locate message - 1 in MeshError message library."
Even after this message my simulation works, so I am wondering if because of this message the simulation is providing incorrect data or something? Is it something I should be worried about?
Thanks!
September 25, 2018 at 12:15 am
September 25, 2018 at 12:41 am
knnn
SubscriberI am rotating a magnet in a tube, and I am seeing this message when I am running models that are about 60 mm in diameter
September 25, 2018 at 12:59 am
pgl
Ansys EmployeeThanks.
So the message goes away at larger diameters? If so try adjusting your Initial mesh settings. Maxwell 3D > Mesh Operations > Initial mesh Settings.
See here in the online doc. Try a finer resolution (slider to the right)
If that doesn't work, then one of the Maxwell experts in the community should chime in soon.
September 25, 2018 at 1:01 am
knnn
SubscriberI have put the initial mesh settings at the maximum, and it is still giving this message. This message was not there when I was running initial models.
- Maxwell, HFSS or Q3D?
- Error
2688
2130
1349
1136
461
