TAGGED: ansys-workbench, error, maxwell, steady-state-thermal
November 20, 2020 at 6:54 pm
arshiah
SubscriberHello, nWhen I tried to run Workbench files (Maxwell and Steady state coupled) made in 2015 version on ANSYS 2019 version, I get these errors. But when I open the workbench file. The geometry in the Maxwell file is missing, and I am not able to change any parameters Thermal steady state file (it has gone into read-only mode). nSystem.IO.IOException: Access to the path 'C:\Users\usedid\Desktop\foldername\USB Drive\1.Thermal 2D archive\Thermal_2D_files\dpall\global\Ansoft\project_R3_mica insulation.aedtresults\Benchmark_Insl_Rchange_mica.results' is denied.n at Ansys.Ansoft.CoreAddin.Migration.MigrationHandlerMoveHFSSDesignerQ3dIntoAnsysEDT.PostProjectLoadDelegate(IFullContext context)n at Ansys.Ansoft.CoreAddin.Migration.PostProjectLoadMigrationHelper.DoPostProjectLoadMigration(IFullContext context) at Ansys.Ansoft.CoreAddin.Events.ProjectReplaceDoneEventObserver.Receive(IEvent eventInfo) at Ansys.Core.Events.EventInvoker.Invoke()nn -
November 24, 2020 at 4:53 pm
ANSYS_MMadore
Ansys EmployeeAre you able to work with 2019 version of files?.ThanksnMattn -
November 24, 2020 at 5:20 pm
arshiah
SubscriberI do not have a 2019 version of these files. Is there any way I can change their version to 2019. I have maxwell and steady state files in the 2015 version of workbench file. n -
November 24, 2020 at 5:27 pm
ANSYS_MMadore
Ansys EmployeeI'm asking if you are able to create new files, just to ensure that your 2019 is working, separate from the specific 2015 projects.n -
November 24, 2020 at 5:31 pm
arshiah
Subscriberyes, I am able to run my other 2019 files, so my 2019 is working. Thanks.n -
November 24, 2020 at 5:35 pm
arshiah
SubscriberOkay, Thank you n -
November 25, 2020 at 9:43 am
mbeliaev
Ansys Employeedo you have EM files outside of WB?nI think this is the simplest way to decouple WB and Maxwell issuesn
- The topic ‘Unable to open ANSYS 2015 files on ANSYS 2020’ is closed to new replies.
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1686
1474
