Discovery Import
Discovery Import
Unable to open scdoc files with double click
    • rg
      Hi
      I have a client who cannot open the scdoc files with a double click.
      I have already reinstalled SpaceClaim and deleted all the files within this path
      C:UsersAppDataLocalSpaceClaim
      C:UsersAppDataRoamingSpaceClaimLog Files
      How can I go about solving it? Do I have to delete all the windows spacecliam registry keys?
      If you need it, I have the .ansys folder
      Best Regards
    • Subashni Ravichandran
      Hello Robert
      The registry key value should be set to the following:
      "C:Program FilesANSYS Incv195scdmspaceclaim.exe" "%1" "/USERUNNINGSPACECLAIM=true" /UseLicenseMode=true
      /UseLicenseMode=true is necessary to make Discovery SpaceClaim look for the subscription license.  Without that set it will look for a floating license, which is why you get the error in the image you submitted.
      Please let me know if this resolves your issue.
    • rg
      Subashni Hi Subashni
      I will let you know if it works
      Thanks
    • rg
      Subashni
      Now it works, however it is strange that the first installation does not work the opening of the native files, it usually works always
      Regards
Viewing 3 reply threads
