Unable to patch regions in Fluent
    • cn18rde
      I am analysing a Volume of Fluid model and would like to patch a region of water, when the rest of the domain is air. I have mark a region using the adapt tool, and loaded 2 phases into my model.
      However, after I initialize the model and try to patch the marked region, the 'phase' drop-down arrow does not show any phases/does not work.
      Does anyone have any ideas?
      Thanks
    • Keyur Kanade
      Select register to patch and then check if it populates other fields. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • cn18rde
      Apologies but the drop-down arrow still does not work even when I highlight a 'register to patch' region. I also get this error message whenever I click 'standard initialization' or 'hybrid initialization' which I am not sure if it is related. nError: CAR: invalid argument [1]: wrong type [not a pair]nError Object: ()nn
    • cn18rde
      The problem is solved, thank youn
Viewing 3 reply threads
