Ansys Products
Ansys Products
Unable to run Discovery Live although laptop meets minimum requirements
    • Ibbyza
      Hi, I am not able to run discovery live on my laptop although the specs clearly meets my requirement. After running the setup, a pop shows that my device IS COMPATIBLE with the programme . However, when i try to run discovery live, another pop up shows that my device is NOT COMPATIBLE with discovery live.
      SPECS (GIGABYTE AERO 15 CLASSIC)
      16gb ram
      i7-9750h 2.8 ghz
      gtx 1660 ti with 6 gb vram, Turing acrhitecture with latest Nvidia driver installed
      Can you check the programme is using the NVIDIA card and not the motherboard one?  Right click on the programme icon and use "Run with Graphics Processor".
    • victorlm
      Thank  you @rwoolhou for the tip, it worked perfectly for me.
      I am even ashamed for haven't tried it before
      However, thanks.
    • Ibbyza
      Hi Sir, Yes i have tried that, the word (default) is already next to my Nvidia GTX 1660 TI processor therefore showing that my Nvidia gpu is being used for the programme as u can see in this image below. The image below that will be what ANYSYS discovery live shows me after i click 'high performance Nvidia processor'
      Thank you for your time and help, hope i can get this issue resolved.
    • tsiriaks
      Please try all of the suggestions posted on here
      https://studentcommunity.ansys.com/thread/discovery-live-encountered-a-problem-right-when-simulation-would-start-gray-window/
    • Ibbyza
      Tried all as u have mentioned, reinstalled with no antivirus active in my laptop.. still blackscreen. I think it has smth to do which why Discovery live is using my Intel graphics for rendering and not my 1660 TI. Are there anyways to change this?
    • tsiriaks
      You can try this
      right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be "High-performance NVIDIA processor”.
Viewing 6 reply threads
