August 16, 2023 at 8:49 am
Cristina Teleanu
SubscriberI am trying to run the LS-DYNA heart valve tutorial on the HPC, using MPI. It runs for about 10 seconds and then I get an Error Termination with the below error message:
___________________________________________________
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Date : 03/10/2022 Time: 06:59:30 |
| Version : mpp d R13 |
| Revision: R13.1-138-g8429c8a10f |
| Features enabled in this version: |
| Distributed Memory Parallel |
| CESE CHEMISTRY EM ICFD STOCHASTIC_PARTICLES |
| FFTW (multi-dimensional FFTW Library) |
| ANSYSLIC enabled |
| Licensed to: |
| Platform : Intel-MPI 2018 Xeon64 |
| OS Level : Linux CentOS 7.8 uum |
| Compiler : Intel Fortran Compiler 19.0 AVX-2 |
| Hostname : d8s3b3.arc4.leeds.ac.uk |
| Precision : Double precision (I8R8) |
| Unauthorized use infringes Ansys Inc. copyrights |
|___________________________________________________|Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
[license/info] Successfully checked out 1 of "dyna".
[license/info] --> Checkout ID: d8s3b3_arc4_leeds_ac_uk-scct-215201-000002(days left: -1)
[license/info] Successfully checked out 11 of "FEAT_DYSMP".
[license/info] --> Checkout ID: d8s3b3_arc4_leeds_ac_uk-scct-215201-000009(days left: -1)
[license/info] Successfully started "ANSYS_LSDYNA".
*** Error 70022 (OTH+22)
Please file a Service Request (SR) via the ANSYS Customer
Portal at https://support.ansys.com.
Customers using an academic license may seek assistance
at https://forum.ansys.com
E r r o r t e r m i n a t i o n===================================================================================
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 214872 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 214873 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= KILLED BY SIGNAL: 12 (User defined signal 2)
= RANK 2 PID 214874 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 3 PID 214875 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 4 PID 214876 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 5 PID 214877 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 6 PID 214878 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 7 PID 214879 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 8 PID 214880 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 9 PID 214881 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 10 PID 214882 RUNNING AT d8s3b3.arc4.leeds.ac.uk
= RANK 11 PID 214883 RUNNING AT d8s3b3.arc4.leeds.ac.uk
I am using Ansys licensing but had installed LS-DYNA R13.1.0 separately as the HPC only had the R11 version available.
Could you please advice? -
August 17, 2023 at 3:43 pm
Ram Gopisetti
Ansys EmployeeHi,
based on your last statement, I guess you need to have a license to add in the keys for R13 and higher,
does the same behavior happen using R11?
Cheers, Ram
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2963
1449
1322
