Photonics
Photonics
Unable to run Lumerical (FDTD) simulation – “Unallocated engine”
    • Ahsanul
      I am facing some troubles when running my simulation. Neither it starts running, nor show results. a snapshot is added below:
      what does it mean? what should I do ?
    • Lito Yap
      Please try the suggestions on this post. i.e. Delete/Remove the INI files from your user folder first, before doing a "clean install".
      Best Lito
    • Ahsanul
      okay, I'll check and follow the steps
    • Cparasch
      Did you have any update? Same here.
      Thanks in advance!
    • Lito Yap
      Did you delete the Lumerical preference.ini files as shown in Step #4 from thispost? Otherwise, try to do a "clean install" as shown in the post.
Viewing 4 reply threads
