Unable to save the simulation. Gives error in the Fluent TUI.
    • ShwetaK
      Hi,nAfter I save the Workbench or Fluent file, I get the following error in the fluent TUI:nWorkBench Error: Could not register filenError Object: #fnThen it makes me revert to the previous version. n
    • Karthik R
      Administrator
      Hi,nDo you see this behavior on any WB file? Or do you only see this for one particular WB file?nCould you please try and start a fresh WB instance and create a simple Fluent pipe flow model to see if you are able to save the model?nThanks.nKarthikn
    • ShwetaK
      I have been seeing it from past couple of days! I thought my files were corrupted.nThat's why I started from scratch but still same error after saving it couple of timesn
    • DrAmine
      Which release version,? Can you empty you temp folder? n
    • ShwetaK
      It is 2020 R1n
    • DrAmine
      Did you check the temp folder? Could you test a dummy project?n
Viewing 5 reply threads
