Unable to select Discrete Transfer (DTRM) in Fluent Radiation Model
    • ricardolion
      Hi Guys,
      Is there any reason why I could not select Discrete Transfer as the radiation model while using Fluent? (greyed out)
      Is it because I am using ANSYS Student or is it because there is something wrong with any of the setting?
      Thanks
      Are you running in parallel?
    • ricardolion
      Yes, I did checked the run parallel version in the setup process
    • DrAmine
      Not available on more than one node.
Viewing 3 reply threads
