August 22, 2023 at 5:03 pm
Karl Johnson
SubscriberI am trying to select multiple modes with selectmode but it returns the error "argument of selectmode must be a string or scalar matrix":
There are 4 solved modes, and I can select both 1 and 2 individually, so that is not the problem:
This is the same as the syntax used in the documentation:
What am I missing here?
August 22, 2023 at 7:18 pm
Amrita Pati
Ansys EmployeeHi Karl,
This is strange, I am able to use the exact same command successfully selectmode([1,2]); May I know which release of Lumerical you are using? Thank you!Regards,
Amrita -
August 22, 2023 at 8:10 pm
Karl Johnson
SubscriberThis is version 2021 R2. I do not have a chance to update right now (I found a workaround so I don't have to use selectmode anymore), but once I update to the latest version I will check whether the issue is still present.
August 22, 2023 at 8:12 pm
Amrita Pati
Ansys EmployeeSounds good! Please let me know if you still see the issue after updating. Thank you!Â
Amrita
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7774
4504
2971
1449
1322
