Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Unable to solve error in simplorer
    • waqas99
      I am constamntly gettinfg this error. i am designing a wireless power transfer system at 2.5 kHz.
      The error is >>
      "Simplorer requires the source solution 'Setup1 : LastAdaptive' to have a frequency sweep of at least '20' points."
      I have updated the frequency sweep list. but still its not working.l
    • HDLI
      Hello waqas99,
             I suppose you are using dynamic eddy current linking, is it?
             Could you delete Maxwell results and rerun the model? Thanks.
      HDLI
    • waqas99
      Thanks, it worked.
    • ZUBAIRULLAH ashtari
      I have the same problem; I try to modify frequency sweep by any try the frequency sweep is not changing. Please help me to solve my problem.
    • waqas99
      There has to be atleast 20 frequency steps. To not make it confusing for  you, you can select step count instead of step size and the count has to be 20.
      I hope it helps.
      Waqas
      Thank you for replying, I changed the parameters based on your instructions. When I add or replace the list again unit instead of kHz, 10^-6 GHz comes.
    • HDLI
      Hello ZUBAIRULLAH,
             Could you delete all solutions and clear all frequencies, then add new frequencies? I suppose the old frequency results are still saved, so you could not delete them. Thanks.
      HDLI
      IT DID NOT WORK.
      I am designing a wireless power transfer system at resonant frequency of 150 kHz ,  start frequency: 50kHz, end freq:300kHz, sweeping frequency: 25kHz in Ansys Maxwell , after inserting my model in  Twin Builder  and same frequency modification. I still get this error
Viewing 9 reply threads
