August 18, 2018 at 11:20 am
KumarVaibhav
SubscriberI am simulating a metal sheet plate case with one end fixed using a cylindrical support alike cantilever i successfully applied all the boundary condition sbut if fails too solve with the following error message.What should i do?Pls see screenshot
August 18, 2018 at 11:43 am
Subscriber1) Remove the distributed mass. You can have the same effect by increasing the density on the material to create the extra mass on the bed frame part.
2) Which face is the Fixed Support scoped to?
Under Analysis Settings
3) Turn on Large Deflection
4) Auto Time Stepping set to On
5) Initial Substeps 50
If you get another error, under Solution Information show a screenshot of the Force Convergence Plot.
6) Show the faces used to connect the long cylinder to the bed frame in the Contact definition, which I assume was Bonded.
7) Insert a Contact Tool under the Connections folder and Generate Initial Contact Status and show a screen shot of that table.
Replace the solid bodies with surface bodies and mesh with shell elements instead of solid elements.
August 18, 2018 at 11:53 am
KumarVaibhav
SubscriberOk removed the mass setting.
Substep 50 is not accepting it shows a yellow sign.See it solves but look at the project tree it shows some different green sign tell me why please?
August 18, 2018 at 12:00 pm
SubscriberInitial Substeps have to be < Maximum Substeps, so make Max Substeps 500.
You did a Background Solve instead of a Solve using the pulldown next to Solve. Just RMB on Solution and Get Results.
How many faces are you applying pressure to? If you apply it on opposite sides, then it just cancels out and the net force is zero.
August 18, 2018 at 12:17 pm
KumarVaibhav
Subscriberi dont know how it happened the RMB solution i just didnt intend to do it.What should i do to restore the default settings as earlier and want to see the reults as itis by default.
i am applying pressure on the all sides front back and the two side faces
August 18, 2018 at 12:22 pm
Sandeep Medikonda
Ansys EmployeeVaibhav,
See if some these resources help in debugging:
Resource 2: Old resource but convergence concepts still hold.
Sandeep
August 18, 2018 at 12:25 pm
KumarVaibhav
Subscribersee what the solver output says
August 18, 2018 at 12:54 pm
KumarVaibhav
Subscriberpeter i am not able to get results even after clicking right mouse button?How should i get back to my older result form where it gets a green ticked mark pls explain
August 18, 2018 at 1:02 pm
SubscriberRMB on Solution and Clear Generated Data.
Click on the Solve pull-down. There are usually two choice:
- My Computer and
- My Computer, Background.
Select My Computer to solve normally.
However, the Solver Output shows that you are not connected to the License Server
You have to fix that before you can solve. First thing to try is Restart your computer.
However, that may not fix anything because of the problems described in this thread.
Please show a screen snapshot of the License Status.
August 14, 2019 at 11:51 am
martoniollo
SubscriberPeteroznewman, i have the same problem, please help me.
Doing the My computer, Background it goes, but only Solve, no. What is the difference between them?
2124
1349
1136
461
