unable to start set up in fluent
    • Rizwan
       After geometry and meshing when I am going into set up of ansys fluent 18.2 I get a failure report which looks like this(2D laminar steady state flow).What could be wrong.
    • DrAmine
      1/Did it work before?
      2/Did you carry out the installation as Admin
      3/Can you try to start outside of the Workbench
    • Rizwan
      I am using fluent for the first time,heat conduction and structural models worked properly.Installation was done in usual way
    • DrAmine
      1/Did you carry out the installation as Admin
      2/Can you try to start outside of the Workbench
    • Keyur Kanade
      go to windows start menu and type fluent. Then open this standalone fluent. Are you able to open this?
      What is your mesh? 2d, 3d? what is its quality? what is orthogonal quality?
      did you give any named selection? please check if there are any overlapping named selections. Correct overlapping ns if any.
    • Rizwan
      I updated the IE from 8 to 11 and the problem was solved
Viewing 5 reply threads
