Ansys Products
Ansys Products
Unable to start the installation process
    • lepetitprince
      I have downloaded the academic version of Ansys product, AnsysACADEMICSTUDENT_2020R1_WINX64 to be exact and I cannot start the installation process. I unpack the archive and double click the setup.exe file. I run it as administrator.
      I closed every application I had opened, but I cannot click on anything there. Literally, it's like clicking on text that doesn't do anything. I tried to click to the Getting started - Installation , I expected pdf file to be opened but nothing really happened. I cannot pass that screen.
    • tsiriaks
      Check this
      https://studentcommunity.ansys.com/thread/discovery-live-installation/
    • lepetitprince
      Thank you for your answer. I solved this in the meantime on my own I just forgot to report back.
      I unpacked the installation archive to the desktop so it didn't work. I moved the installer to D and it run properly.
      When I tried to run workbench, it didn't work because of ? in my username, so I opened new user account in windows without non-english letters and just run the program I already installed. And it worked.
      Is there any way to get it (workbench) to work with AutoDesk Inventor though?
    • dsurendr
      You can run the CAD configuration Manager with Right click and Run as Admin from Start Menu > ANSYS
      Then click the checkbox for Inventor and select the Workbench Associative Interface Option > Next > Configure selected CAD interfaces
      Does it say success?
      After this, when you open Inventor > Do you see Workbench Plugin?
    • lepetitprince
      Prerequisites ..... Configure Success
      AI  Workbench PlugIn ..... Not Configured
      CAD Configuration log file was written to location:  D:Program FilesANSYS IncANSYS Studentv201CADConfigLogsLatestCADConfigurationMgr.log
      That's all I get. The log says:
      Invalid Inventor Dll File Path in createAnsRegistryXML2 D:Program FilesANSYS IncANSYS Studentv201aisolCADIntegrationInventorwinx64DSPlugInAICOM.dll
      No valid Inventor installation detected
      Writing packageinfo to: C:UsersMarko Todorovic.DESKTOP-MKFBFJPAppDataRoamingAnsysv201ProdConfiguninst_data.dat
      WritePackageInstallData Succeeded.
      SpaceClaimEngineering Not Detected
      Saving to D:Program FilesANSYS IncANSYS Studentv201commonfilesCADCADConfigurationInfo.XML
      WriteUpdateConfigurationStatusFile Update Success
      Everything is installed on D partition since the laptop has 128gb SSD and it's not enough for CAD software. Is that making a problem here?
    • tsiriaks
      This functionality is not included in ANSYS Student version.
      You can check
      https://www.ansys.com/academic/free-student-products
      select the product -> "what's included" -> "Geometry Import"
Viewing 5 reply threads
