Unable to start the mechanical and geometry editor in Ansys workbench 14.5
    • Joseph Lim
      Dear community,
      Attached is the error that I encounter when I start to open the mechanical and geometry editor. May I ask for some suggestions and help with those problems?
      Thank you very much in advance.
      Joseph
    • peteroznewman
      Is the problem you are asking about that there are no tools in the toolbox?
      For the toolbox issue, I assume you have tried a restart on your computer.
      Is the license local to that machine or is there a license server that machine needs to communicate with?
    • Joseph Lim
      Hello Peter,
      Yes, I have a problem with the toolbox issue. I have tried to restart on my computer numbers of times but I still have the similar problem.
      I think is a license server that machine needs to communicate with.
      Joseph
    • Bhargava Sista
      Joseph,
      Try these steps:
      • Close all open WB sessions.
      • In Run, type %appdata%, this will open the Roaming folder. Open the folder named Ansys.
      • Since you're using version 14.5, look for a folder named v145. Rename it as v145_old.
      • Now open a new WB session, see if this resolves the issue.
      Let us know if that helps, cheers!
    • Joseph Lim
      Hi Bsista,
      Thanks for the suggestion. I had tried using other approaches which I reinstall the software (Ansys Workbench 14.5). The problems solved after I reinstall the software.
      Cheers!
      Joseph
    • Tarek20
      Hello every onennI am facing a problem related to open a new design modeler while clicking on Geometry it shows the following message as shown in the picture . nn
Viewing 5 reply threads
