February 9, 2022 at 4:31 pm
manuel.uruena
SubscriberI am modelling in APDL an axial loaded shell tube subjected to local buckling, with a force load and arc-length method. I have introduced geometric imperfections.
My solution always stops due to uncovergence at the maximum load before the negative slope of the load-displacement curve, and local buckling does not take place yet. The error message is that the arc-length method reached a minimum. If I use a small value for minimum mutiplier in arc-length method, unconvergence still occurs, but no longer with the reached minimum error message. All coloured lines of solution suddenly drop down.
I have tried playing with a large number of substeps, a very small MINARC value, lowering the MAXARC value to 1, changing from CERIG to RBE3 constraints, increasing number of maximum iterations to 50, lowering the equivalent plastic strain in cutback controls to 0.05,... etc.
How can I achieve convergence?
February 10, 2022 at 5:57 pmAshish Khemka
Please see if the following discussion helps you.
Arclength method does not gives converged solution in buckling analysis ÔÇö Ansys Learning Forum
Regards Ashish Khemka
February 10, 2022 at 6:09 pmViewing 2 reply threads- You must be logged in to reply to this topic.
3648
2522
1745
1226
578
