January 31, 2023 at 10:20 pm
Liza Gunther
SubscriberHi all,
I'm using HFSS to model the H field on a solid object. I've exported the H field as a .dsp file, and I'm struck trying to recreate the field map in python. I know the element solution gives the field values for the body, but I don't know how to differentiate the x, y, and z elements as they are all in one list. Does anyone know the format of the coordinates in a .dsp file?
Thanks in advance.
February 4, 2023 at 2:12 pm
Jakke Dak
SubscriberIts nominal power is 280W. Its coils consist of a stranded winding with 24 thin wires with 5 turns. The https://testmyspeed.onl/ software has calculated its locked rotor current as 850 Amps.
February 7, 2023 at 12:35 pm
Praneeth
Ansys EmployeeHi Jakke,
It looks like your response is out of context of the original thread. Please check once.
Best regards,
Praneeth.
February 7, 2023 at 12:31 pm
Praneeth
Ansys EmployeeHi Liza,
Thank you for reaching out to us and we appreciate your patience.
Please provide more information to help us serve you better:
- Give the steps you have used to export the field in dsp format.
- Do you have to use the dsp format only?
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
5242
3297
2467
