Discovery Import
Discovery Import
Understanding the transmission spectral response change with center wavelength
    • rakeshmk
      Bbp_participant
      I am running a simulation for  a grating coupler. One check I performed is to observe the sensitivity of the coupling/transmission response w.r.t the launch wavelength of the source. In the simulation, I am using a gaussian source with certain beam waist, angle and distance pertaining to a real world experiment.
      I noticed that when I change the center wavelength of the source, the transmission response at the transmission monitor on the taper end of the grating shifts (image below). Theoretically, the response shouldn't change w.r.t the launch wavelength/center wavelength of the source. But why does the simulation show otherwise?
      (is there a source normalization happening here that I missed out considering)
    • Devendra Badgujar
      Hello Rakesh Krishna
      Regarding your question on Ansys Lumerical, please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Thank you for your understanding!
      Regards.
    • rakeshmk
      Bbp_participant
      Thanks Devendra.
      -Rakesh.
    • rakeshmk
      Bbp_participant
      Hi Devendra
      I couldnt access the learning forum. I could open it in the morning, but clicking the post button doesn't process any further. Now when I try it again, it shows that the server is under maintenance. I need to get my question answered at the earliest. Can you let me know what's going on?
      • Devendra Badgujar
        Rakesh Krishna
        Please try this link Ansys Learning Forum. Let me know if the problem persists.
        Regards.
    • rakeshmk
      Bbp_participant
      Still doesnt seem to post. It goes on.
      • Devendra Badgujar
        Rakesh Krishna
        I will check with the team and get back to you.
        Regards.
    • rakeshmk
      Bbp_participant
      Hi Devendra
      Its okay on my end as I have my question answered separately.  Its just that I couldn't post on this discovery forum.
      Thanks,
      -Rakesh
Viewing 5 reply threads
