March 20, 2022 at 9:43 pm
mg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Had unexpected behavior during the first stage of a design, and wanted to ask if there's another method, or if I'm using a tool incorrectly?
First attempt (v3 photos) was using the sine equation in sketch mode, then pulling a small round surface along the path. The result of the sine equation was an unexpected group of many curve segments, with each having an unusual segment length, rather than a single smooth curve. The pull operation resulted in a solid with strange joints at the end-point of each segment, an irregular non-circular surface, and sharp angles between segments.
Second attempt (v4 photos) was to use the previous sine curve(s) as a template, and sketch a single spline from added reference points. When the round
surface was pulled along the spline, the solid was completely distorted and not on the spline path. scdoc files also enclosed. Thank you. -
March 21, 2022 at 5:37 am
Devendra Badgujar
Ansys EmployeeHello maike
Let me look into this and get back to you.
March 21, 2022 at 12:52 pm
Devendra Badgujar
Ansys Employee🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hello maike
Please check the attached video demonstrating the above process of creating spline using sine equation in sketch mode.
Please let me know if you have any further questions on the same.
Regards.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1236
592
