February 16, 2022 at 7:27 pm
Kabelka2001
SubscriberHello!
I would like to install the latest student version, but I always run into the same error when I run the workbench.
https://drive.google.com/file/d/1OKVbdr1wZgbwc957ei8p0_zwqGTQWvyn/view?usp=sharing
I've read about similar problems on the forum, but unfortunately, I still can't get the application to start.
February 16, 2022 at 7:41 pmGeorge Karnos
Ansys EmployeePlease post the error as we are not permitted to download or open any files.
Thank You.
February 16, 2022 at 8:46 pmKabelka2001
SubscriberThe error text is:
,, Unexpected error: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit."
Thank You!
February 17, 2022 at 1:32 pmRob
Ansys EmployeePlease search on here for the error message, it's been seen several times before.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3744
2573
1821
1236
594
