January 1, 2023 at 12:24 pm
w d
SubscriberHi, been struggling to find the solution for this for a while, under all flow conditions it complains that the wall is too close to an outlet even though it's 20c downstream and 10 C above and below.
I get results but best i can get is CD is about 60% higher than it should be compared to data from theory of wing sections.
if i try running it at m 1.2 there's a triangle of very high speed flow in the bottom right of the enclosure, and i can only run this at 0 aoa otherwise it just throws an error about the max mach number going up to mach 7 or so, then crashes
Using cartesian components to simulate AoA so front and bottom are inflow and top and back are outflow.
I'm really out of ideas here...
January 2, 2023 at 12:39 pm
C N
Ansys EmployeeHello
I suggest you to refer this Ansys innovation course on compressible flow over airfoil simulation set up. Hope this will solve your problem
Airfoil Simulation Example | Ansys Courses
Thanks
2564
2080
1293
1106
459
