May 25, 2022 at 12:52 pm
June 1, 2022 at 8:49 am
Anchal Singh
Can you please let us know which helix design you are simulating in HFSS? Did you design it inside HFSS or import it from somewhere else?
After what value of turns does it start throwing the same error?
Please provide more screenshots to understand your problem properly.
Regards
Anchal
- Maxwell, HFSS or Q3D?
- Error
3666
2534
1749
1226
580
