August 24, 2023 at 10:05 am
subhav goel
SubscriberHi everyone, I am performing a static structural analysis in ANSYS 19.2. between a cylinder and a plate in contact. When using structural steel I am able to get a gap in the contact area, which is as expected with a frictionless contact. But as soon as I changed the material to Quartz glass, there was no gap between the contact surfaces for the same boundary conditions. I am unable to understand why this is happening.
August 24, 2023 at 10:57 am
Sampat Kumar
Ansys EmployeeHi Subhav,
Have you changed the material in the same model or are you running two different models? Is this happening with the Quartz glass only or with other materials also? Please let me know.
Sampat-
August 24, 2023 at 12:35 pm
subhav goel
SubscriberHi Sampat, I changed it in the same model. I have checked it only with cast iron or as a cast iron cylinder and aluminum plate. for both of these models, I was able to get a gap, but there was no gap when I had a Quartz glass cylinder
Regards
Subhav
August 24, 2023 at 11:34 am
subhav goel
Subscriber -
August 25, 2023 at 2:10 pm
Sampat Kumar
Will you please upload the screenshot of the model and contact status of both simulations? Also, upload the screenshot of the contact's settings.
Sampat-
August 25, 2023 at 5:22 pm
subhav goel
Subscriber-
September 5, 2023 at 9:45 am
subhav goel
SubscriberHi Sampat could you think of any reason for these results
September 6, 2023 at 3:29 pm
Sampat Kumar
I apologize for the delayed response.
I can see you have attached the result of the contact tool under the solution. Please verify, if you selected the proper contact and target side in the contact tool while evaluating the result. I have created the dummy model and checked with the same version but did not find any differences.
Although your value is also small. Is this value-creating any issue in your result? what is the penetration and geometric gap value in the contact tool status under the connection?
Sampat
4440
2953
1427
1322
