January 25, 2023 at 12:20 pm
Biborka Boga
SubscriberHi. I am working on the simulation of liquid film flow in an inclined channel (35 degree compared to the horizontal position). I am modeling only a reduced segment of the channel (1.32 mm) using the mixture multiphase model.
The problem is that even along the modelled channel length, an uenxpected thinning of the liquid film has been observed (please find below).
Can you please offer me some hints why this considerable thinning of the liquid film can be observed?
Thank you very much in advance your response!
January 25, 2023 at 12:59 pm
SRP
SubscriberHi,
Did you specify both the component of gravity based on the inclination?
Can you please share boundary condition, multiphase setting, and turbulence models use?
Thank you
Saurabh
January 25, 2023 at 3:27 pm
Biborka Boga
SubscriberFirst, thank you very much your feedback.:)
Please find below the specifications:
- laminar (viscous settings)
- I have defined g considering the inclination (i.e., angle) of the channel relative to the horizontal position, namely g for X: g*sin(angle) and for Y=-g*cos(alfa)
- Mixture mutiphase model
Regarding to the BC at the inlet I have had velocity inlet, and at the otlet pressure outlet. I have defined a symmetry BC, and wall BC (for the upper wall, sidewall, and bottom).
Thank you very much in advance your hints.
Although a certain thinning was expected, but not as much (as in the current simulation).
January 25, 2023 at 4:35 pm
Ansys EmployeeIt's because it's a liquid so is flowing (accelerating) downwards. With VOF there's an open channel boundary which avoids this issue, but that'll cause problems with the phase change model(s).
January 26, 2023 at 7:17 am
Biborka Boga
SubscriberThank you very much your response! :) I totally agree with you regarding to the open channel BC (VOF), since I have applied it as a first approach.
I will try to find a solution. Thank you again for all!
2656
2120
1347
1118
461
