Unexpexted error SIG$ABORT
    • Talla
      Hi guys,
      i have a big model with a static analysis, a modal analysis and 3 harmonic response. that model was given to me by my supervisor. for the same model every thing was ok for him and when i do the calculation, i go through many problems. i have succed to solve some of them.
      the problem that i am facing now is that i can't run the harmonic response, i always have this error below.
      any tips will be really helpfull.
      thank you!!
    • peteroznewman
      Restart your computer,  delete the files you were using and try again with the original copy of the files you were given. Does the problem repeat?
    • Talla
      Thanks Peter for you response, unfortunately i already try that and the error come again. i am trying anothing now, i will let you know if  it works or not.
    • Talla
      i am still getting it so any tips may be helpful
Viewing 3 reply threads
